Horrid idle, please help
Brevity, per your first post, is the absolute last thing you want with this kind of problem. I would not do anything else until you check your CIS fuel pressures (system pressure, then cold control and warm control pressures).
Then, it does sound like a lean condition. Is your airbox sound? Do you have a pop-off valve? Is that epoxied in well, and is it sealing well?
Brett
Brett
You need to explain things better the first time around, if you want help here. Your new story presents a different picture. It seems you omitted the part about it being fine until a few days later Tough to stay interested now....
Check all your hoses and vacuum lines, plug wires still on, etc. You are the one that needs to look for the low hanging fruit. We can't. That is what I'd look for, something that came loose after your work.
Brett
Brett
Anyway, I'd get it running and tuned well, then revisit the pop-off valve. No need to introduce another factor at this point.
Brett
I think fuel pressure is up next. I dont kniw squat about cis systems, but a clogged fuel filter or check valve would not surprise me. Try tapping on the fuel pump with a plastic mallet. There is also a cold start enrichment valve that opens while cold. It raises the idle until the motor is warm.
my car doesnt have a pop off valve and runs flawlessly .. putting one in will NOT fix your problem .. however you could have a blown airbox or some other massive unregulated air leak ..
Haven't done the fuel pressure test yet, need to get a jumper and will hit that tomorrow. But I need some help with an electrical issue that MAY be related. Reading the Bentley manual, it sure sounds like it MIGHT be a control pressure regulator issue. ? Per the manual I checked the connection, but am NOT sure I'm doing it right. The manual reads as follows:
If the control pressure does not increase as the engine is warmed up, the heating element within the regulator may not be functioning. Check that the heating element in the regulator is receiving voltage. If battery voltage is not present at the connector, check for ground at the brown wire in the connector. Check red/white wire for positive voltage coming from terminal 30 of the fuel pump relay. If no faults are found, the heating element in the regulator may be faulty
Well here's my findings, there is NO voltage at the connector at the regulator, flickered like .02 volts. I assume I do this with ignition on (car not started)? I kept the ignition on and tried to get voltage at terminal 30 in the socket where the relay plugs in, no voltage there. I cannot find the brown or red/white wires since they're wound tightly, buried and hidden in the bowels of the car. Might this be an issue? Don't want to start tearing into the electrics if I'm way off base here, but I'm pretty darn positive I find no voltage coming and wondering if a corroded wire or faulty ground is to blame.
If it were me I'd just go ahead and order a new control regulator. Given the age of it I'd replace it. I was working on my ac in my 89 the other day, it was upgraded by previous owner but the vent temps were terrible. I got in the smugglers box and checking things the ac blower relay was hot hot hot, so I ordered a new one. Just installed yesterday went for a 10 minute drive with ac on pulled back in the drive way and vent temps were 30 degrees........a simple relay was all it needed go figure.
The heater should just be a coil of wire, no? Does it have continuity or is it open circuit? It's not uncommon for the heater coil in the auxiliary air regulator to go open circuit.
Although voltage supply is a separate issue. I don't know how the air sensor plate switch is wired, but the fuel pump does not run unless the engine is turning (drawing air into the intake to raise the sensor plate and trip the switch). Does this mean that all circuits going through the fuel pump relay also have no power unless the engine is running? I don't know, but if that is the case, you'll need to have the engine running, not just ignition turned to on. It stands to reason that this heater would not operate unless the engine is running. It's supposed to warm the regulator control mechanism to simulate engine warm up. You wouldn't want it acting like the engine is getting warm with just the ignition switch in the on position when the engine isn't actually warming up. I'd check for voltage at the connector again with the engine running. You could just lift the sensor plate at the same time as checking the voltage
Brett
Brett
Rusnak, I didn't get a light with the low voltage test LED. Brett, those are good points. I will try it with th engine running. I want to be sure I'm on the right thing. As I'm facing my engine, the control pressure regulator (same as the warm up regulator?) is on the left between the first and second cylinder. I disconnect the harness on top to check voltage. Was not sure if I should do this with the car running, but will try.
