911 Forum 1964-1989
brake fluid
Old Jul 20, 2011 | 09:08 PM
kirallahi's Avatar
kirallahi
Default brake fluid
what s the level in the brake fluid container,i can t find it on mine.....and i dont know if i need to remove air from the lines when i ll add brake fluid......
Old Jul 20, 2011 | 09:22 PM
wildcat077's Avatar
wildcat077
Salut Ingrid,
You should have two lines on your reservoir,one for low and another for full ...
Just make sure you're always close to the full mark.
No my dear,you don't have to remove any air when you're just adding fluid !
Send me a message on my hotmail,i'm on vacation and i could help you out with your car
Cheers !
Phil
Old Jul 21, 2011 | 12:48 AM
rusnak's Avatar
rusnak
I haddah Google dat
Hmm..not sure of the answer. I just fill it to just above the metal band. You should be able to use a small screwdriver to pry out the plastic mesh screen so you can actually see the fluid level if you're not sure. The float has to come out too. Use paper towels to make sure you dont drip any fluid on the carpet.
Old Jul 21, 2011 | 10:26 PM
kirallahi's Avatar
kirallahi
thank s everybody :
