H4 Kit - Possible Options
Hi Folks, Moving forward on tweaking my '87. I've been reading about the H4 upgrade after a rather dim evening ride back from a friend's house yesterday. Anyway, I don't want to spend $500 for the euro H-4 upgrade, necessarily.
Will this setup work just as well in terms of extending night visibility?
http://www.pelicanparts.com/cgi-bin/...i?pn=70476-M44
http://www.pelicanparts.com/cgi-bin/...=JWST-911-HLPR
Is there a major advantage to the euro setup that would be worth the ca$h? I quite like the look of my setup as-is. Anything else I need to do the upgrade that I didn't list here? Just trying to save a little cash on this upgrade and sort of wondering if there is anything comparable to the euro setup for less money. Thanks for your help.
Actually, as I read Pelican's description again I see that the parts list I have might only be for the '86....making the euro upgrade the only option?
Kevin
Kevin
Your 87 will have H5 lenses. If you want to change to H4, you need to redo your headlght plug. Once you do so, you can use either the Euro or the upgrade H4 on the sugar scoops. If you go with the sugar scoops, you will need the entire headlight assembly with mount and scoops. I am not sure if the H5 equipped cars have the headlight mounting tab at 6 o'clock.
I imagine that the H4 euro lenses (scoops?) account for much of the illumination efficiency as the wattages are the same essentially. Is that the case?
I bought these from ebay...
brand new Bosch, plug and play on my 86, needs light bulbs though.
http://cgi.ebay.com/ebaymotors/2-New...Q5fAccessories
