Front Tires on 17" Widebody?
Looking to either go 245/45 or 245/40 on 17 x 9 Kinesis K57's. Anyone have any input they can give me on which is the better size to go with? Car is at euro height.
Thanks!
Rod
Thanks!
Rod
Doubt it makes any difference. Only thing I've noticed is that bump steer is amplified a great deal the lower the profile/larger the rim diameter. And since it's pretty bad to begin with, even at euro height............
Ok, so I am man enough to admit I do not know what you mean when you are talking about bump steer. Unless you are talking about the ability to steer the car when you hit a bump?!
So you think which size is better? 245/40?!
Thanks!
Rod
Thanks!
Rod
Poseur
When you lower the distance between the center of a wheel (and the suspension) to the ground, but do not lower the steering rack by the same amount, you will get a response when hitting a bump that will twist the steering wheel in your hands negatively. Ideally, you always want to lower the steering rack by the same amount to minimize the impact. Spacers are made to do this--added between the steering rack and pinion device and the body.
i have 245/45 by 17 on my 930. i like the meatier sidewall. do you have 11s on the rear and would you like to swap for a nice set of 9/11 by 17 fikse fm10s. i have been looking for a set of kinesis 57s for a while...
You'll be best served raising the spindles to alleviate the steering issues, IMO. The rack spacers are a joke. I'm not sure about the drop link option, though.
my car is probably a bit low...i just do not know for sure. if interested in followup my email is maxwedge528@charter.net...thanks
