Solex to Weber air filter adapter?
Hello,
My 1965 911 was converted from Solex's to webers some time in its past. I have the original Solex's and Metal air filter. The last mechanic used a plastic air filter that must have come off of a later Porsche. The plastic filter is not a great fit.
I like the looks of the original metal filter and would like to put it on the webers. Is there an adapter kit out there that will adapt the metal filter to the webers?
Thanks.
Thanks.
RL Technical Advisor
Hello,
Thanks.
Thanks.
Assuming you are speaking about installing the OEM air cleaner box, there are no adapters to install the Solex one onto a pair of Webers; they are totally different.
I would post a "Wanted" ad on the Early S Registry Forum for an OEM Weber air cleaner ('66-'68) and hope you find a rust-free example.
