Cleaning solvent for a sticky distibutor ??
What can I use to clean out this area without removing everything? Is a solvent that will not damage the electronics of this area or should I take it to a shop to have it cleaned and or rebuilt?
Rcik
1977 911s 2.7
Cheers,
Sean.
1980 Hellblaumetallic SC Targa.
Waterfree alcahol or solvents like Methylenchlorid are the best as they will not harm electrics even flooded.
BTW your 77 should have a mechanical breaker contact.
Bosch has a special grease for the sliding plate and the fullcrum wights needs special grease as well plus regular drop of oil.
Check if the fullcrum wights work in the factory specs and also if the vacuum canister works within range. If not then its time to pull the complete unit and go trough it. If the bushings are worn or you reach your own limit ( skill or toolwise ) a prof will be needed.
Grüsse
