911 Forum 1964-1989
911 1977 fuel regulator problem
Old Mar 31, 2011 | 11:23 PM
kirallahi's Avatar
kirallahi
Exclamation 911 1977 fuel regulator problem
I recently bought a 911 porsche 1973 with a 1977 2.7 engine swap. I have some problem with the fuel regulator, it has to much fuel pressure. Something like 2,5 times over the normal limit. The car hasn`t been running for the past 5 years, since it was stored. I brought my car to a local mechanic who was able to tell me that the problem was the fuel regulator. Now im just looking for a shop/garage that specializes in older model Porsche 911 in the Ottawa, Ontario region. Any tips or advice appreciated,
thanks
Old Mar 31, 2011 | 11:40 PM
jakeflyer's Avatar
jakeflyer
Why not buy the manual and have a go at it. Tools are cheap and your car is fun to work on.
Old Apr 1, 2011 | 08:20 AM
kirallahi's Avatar
kirallahi
Thanks, I actually did get the manual for it. But I don`t really have the time or resources to do the work myself.
Old Apr 3, 2011 | 05:59 PM
kirallahi's Avatar
kirallahi
i suppose to receive the manual tomorrow....yout yout..
Old Apr 6, 2011 | 10:53 AM
kirallahi's Avatar
kirallahi
Default no more probleme
the probleme with the fuel regualtor was the injecteur probleme.its done now with a good clean up of injc.systeme
Old Apr 6, 2011 | 02:12 PM
whalebird's Avatar
whalebird
depending on what 1973 you have, the fuel pump is probably above the drivers side axle and returns excess fuel to the tank itself. IIRC, 77 had the pump up front under the tank and simply pushes fuel to the engine where the CIS system returns unwanted fuel. The 73 pump (if being used) may well be wrong as the CIS, MFI, and carb models all used a different pump IIRC.
You should have the entire system from a 77 under the 73 for it to work correctly. Which is a good thing...have you priced early car fuel pumps???
Old Apr 7, 2011 | 04:03 PM
kirallahi's Avatar
kirallahi
no price for the fuel pump,but i think i only need adjustment.....what you thik ...
Old Apr 7, 2011 | 07:14 PM
theiceman's Avatar
theiceman
Team Owner
Jump on the Canadain forum for local members in ottawa. Mark Motors should be able to recomend a good indy.
Old Apr 13, 2011 | 07:10 PM
kirallahi's Avatar
kirallahi
thanks for the info .
ingrid
Old Apr 13, 2011 | 10:19 PM
irobertson's Avatar
irobertson
Although I have not used them personally as of yet, I have heard good things about Auto Import on Woodward.
I'm planning to get them to do a corner balance and alignment when I get back on the road.
Old Apr 14, 2011 | 07:24 PM
kirallahi's Avatar
kirallahi
cool thanks
