915 tranny neutral saftey wire
does anyone no if the 915 tranny has a neutral safty wire on it and were it is located. can you grab it in the car somewhere or if there is one do you have to get it at the tranny. car is a 83 911 cab. thanks john
Sounds like you don't want to start the car in gear. If this is the case, why not put a switch on the clutch pedal and use this with a relay so that the car can only be started with the clutch pedal depressed.
Saint.
Saint.
