Charging parallel batteries
3rd Gear
I can't get a straight answer on this (despite searches in rennlist, pelican, and roadfly).
I have a '69 911E (with Webers). My battery charger can trickle at 2 Amps, but somewhere it says not to use it for batteries in parallel. Can I use it for my batteries? Which battery do I attach it to (and how do I attach it)? My batteries are grounded (once) negatively.
If they're in parallel, just connect to one of the 2 batteries and the second will charge automatically. It will draw double the current (but same voltage) as a single battery. Charger says not to charge multiple batteries in parallel because the resistance gets alot lower and it could short out the charger, however, most chargers have shorting protection built in. If it has an ammeter, just make sure you don't exceed 2A as stated...
Grant G---or will it just take twice as long to charge the batteries?? The 2 deep cycle batteries in my motorhome are in parallel and the charger shows the same current draw as one battery--but it seems to take a lot longer to charge the pair of batteries using an automatic charger. <img src="confused.gif" border="0">
Well, it will draw double the current, unless the charger has some current limiting function. Placing the batts in par. means that the resistance is cut in half, which means double the current for a set voltage (Ohm's law). However, it the charger is limited at 2A, for example, then it will take twice as long (like in your motorhome).
Grant--assuming the current is doubled (Resistance halved--Ohms law as you mentioned) for two batts in parallel--would they BOTH now receive the doubled current or would the doubled current then be split between the two batts?
George,
The current would be split between the 2 batteries (Kirchoff's law for current conservation). The battery with the lower internal resistance would receive the higher current; the sum of the current for each battery has to add up to the original current supplied by the charger.
I get confused about the difference between batteries hooked in parallel and batteries hooked in a series. One of the two hookups yields 24 volts instead of 12. I suspect that it what your charger instructions were worried about. The dual battery set-up of the early 911 is designed to be a 12 volt system. I've never had a problem with charging both batteries by hooking a 2 amp charger to either side. I usually do the passenger side because it's easier to reach.
