gt3 wheel alignment
3rd Gear
I have a 997.1 gt3 and drive on PPZs. Rarely use on track and enjoy driving daily. Recent tyre replacement and alignment has created a front end monster at speeds >90km/hr,with poor directional stability. Alignment is stock gt3 setup. What would be best toe/camber/caster for daily driving ? Thanks
I'll help you lad. Go 2.25 degrees camber in the front with ZERO toe. Set up the rear at 1.5 degrees with 2MM toe in. Tires are everything if you are planning on any high speed runs. IMO.
By the way, most shops have no clue how to align these cars. Who knows what you have. Take it to a race shop that knows that they are doing. Starting with Ride Height, Corner Balance. You kick down $800-$1000 to do it right and the car will reward you 100 fold
