Stuck on DIY Lens replacement - Need Help Please!!!!!!
Happy 4th to all! I am trying to replace my lens covers on my '73 today. After removing the old covers, I unscrewed the light housing to remove it so I could cleans things up a bit and put on a new rubber seal. Unfortunately, I can't figure out how to disconnect the $(#*% electrical cord that provides the power to the signal assembly. Without disconnecting this cord, I can't remove the housing and get the necessary space to clean things up.
I know there is probably a simple solution, but I don't want to force things. Any ideas on how to disconnect the cord from the light assembly???
Also, what is the proper glue for attaching the new seals? Thanks in advance!
