1987 911 strange heater question
Hi all. My 1987 911 has a strange heater problem. I've had the blower motors replaced and they work fine - but the turn-dial between the seats will only work up to 9. When it's turned to 10 (demist) the blowers go off. Up to 9 it blows hot air no problem - but just won't give the big blast on 10. Any ideas? Given the continuing cold winter I could do with some more heat! TIA.
I haddah Google dat
I would check the rotary switch to make sure it's not bad. Does the blower run when the engine is reved, or is it always out on setting 10?
