Sub Woofer Speaker Suggestions
6th Gear
Does anyone have any suggestions for a sub-woofer setup for a 86 Carrera ? My sound system sounds great except its missing a little of the sub frequencies. I've looked at Rod's(Audio Innovations web site) application but feel this is much more than I really need due to the compromise of space.
Regional Note:
If there is anyone in the Atlanta, GA area that has "anything" installed, I'd be interested in seeing first hand the way it looks.
RichKenny
86' Carrera
Regional Note:
RichKenny
86' Carrera
7th Gear
Have you seen the Infinity X Link? Sub Woofer
I have one installed in the front compartment and it kicks butt.. I have a Targa with it installed I still have plenty of room for my foldable top and more.
Jorge
Jorge
1 Post
i too had the same dilemma.....i ordered a crutchfield catalog and found a product called a WOOX. its an amp and sub in one that fits behind the seat on the floor....
check it out..
kyle
check it out..
kyle
unless you're requiring the seat all the way back, Rod's setup clears well. I get all adjustment except for the last notch. Not even noticable unless you're looking for it. Much cleaner than having a prefab enclosure floating about behind the seat..
rjp
rjp
I have a 6 inch bass cannon bungee mounted in the luggage compartment, pointed at the cabin and driven with 2 channels from my 4 channel amp using 50W per channel. All the bass I ever need for my Targa, and I really like bass. The cannon can also be quickly removed when I need more trunk space for hauling sofas :-)
No room for the Birch set up in the rear due to growing child and her growing friends.
I have an 8" JL Audio sub mounted under each of the front seats. It is a little custom but really simple to do. It is totaly stealth and never in the way. Both seats work exactly the same as nothing under them. I have my Alpine 5 channel amp mounted in the trunk on the front of the HVAC unit.
Everybody that gets in for a ride asks where the sub box is--I jokingly say it is all door and rear shelf speakers.
6th Gear
Hey Sam,
Do you happen to have any pictures of your install ? How do you have them mounted/secured ? Do you think I could get away with one JL Audio sub ? Also, did you build the boxes ?
Thanks,
Rich Kenny
Thanks,
Rich Kenny
On my '87 Targa I had a Bazooka sub woofer mounted on the shock tower brace with the included straps. It was powered by a 300 watt amp under the passenger seat. I understand that Bazooka has powered versions too. The best part of this setup was that the speaker was easily removable for the track.
_________________
Richard Pankhurst
'87 Targa (sold)
'89 Sunroof Coupe
_________________
Richard Pankhurst
'87 Targa (sold)
'89 Sunroof Coupe
i own a stereo shop and the jl under the seat is the most practical way to put a sub in that car without losing any space. The only negitive is you will have to have a shop build the box for the woofer and have it made to a secific box volume. As far as do you need 2. It depends on how much basss you want. I am building a 10,000 to 15,000 system in my 911sc cab and hope to have it done in 2 months. I will post pictures when it is done.
I have an 8" powered Bazooka behind the passenger seat, fits fairly well. If they make a 6", it should be more than enough for a 911 (the 8" ROCKS, almost too much for me). I installed it with quick disconnects so everything comes out quickly for driving events.
I'm in ATL if you'd like to check it out sometime. I'm planning on going to the 3/23 PCA autox at Turner field if you want to see/listen there. Send me a PM if you're interested in seeing it.
