TDC Sensor NLA? 911 606 108 00
I'm doing a parts search and Pelican shows this as NLA for genuine Porsche.
Anybody else run into this?
If so, what other sources are out there?
The P/N 911 606 108 00 is used on 944, 928 and 968 in addition to the 911.
Seems unlikely it would be NLA completely.
Does Pelican's system show NLA when they are out of stock?
I will be checking with my dealer on Monday but wanted to solicit inputs first.
autoatlanta says they have 10 on ebay but there website says NLA....
http://cgi.ebay.com/ebaymotors/ws/eB...6#ht_500wt_956
I haddah Google dat
The TDC and speed sensors are available at Paragon Products for about 50% of dealer price.
And they are a DEAD MATCH for the stock parts, except you have to use your own label maker to add the DG and BG tags.
Thank Whalebird for this link, not me: http://www.paragon-products.com/Refe...61.210.002.htm
Both the links above (both previous posters) point to the TDC and speed sensors. The original poster asked about the 911 606 108 00 - which is the timing mark sender. Physically it looks different than the TDC and speed sensors.
As the original poster mentioned, it is used in the 911 and the 928 (both my concern as well). I spent some time looking and this item (911 606 108 00) does indeed appear to be flagged as NLA - from various suppliers.
I thought I found a source for this 911 606 108 00 however the vendor had the TDC part with the wrong description.
So I too am curious what others are doing when the timing mark sensor needs to be replaced?
In PET 7 parts diagram, it is item 18 (the TDC and speed sensors are items 13 in the same diagram)
Cheers
Glenn
Cheers
Glenn
I haddah Google dat
My mistake, sorry.
Supposedly that means none of the Porsche dealers have it. I've found that this is not always the case, and one or two may have one. But most likey the best way to get one is to find the Bosch part number and search using it, rather than a Porsche number.
This begs the question.... What fails in these sensors and can they be repaired?
Or, can one of the speed/reference senders be modified to work in the timing mark sensor application?
I'm still confused, but find this interesting...
http://seekpart24.com/search?am=porsche&c=102747
Sensor, crankshaft pulse for Porsche, Volvo
Part Number: 0 261 210 003
Cable Length: 380 mm
Resistance [kOhm]: 0,859
Porsche: 924, 928, 944, 959, 968
154,80 EUR
Contains: 1 item
Sensor, crankshaft pulse for Porsche 911
Part Number: 0 261 210 005
Cable Length: 610 mm
Manufacturer Restriction: order online
Porsche: 911
141,70 EUR
Contains: 1 item
Part Number: 0 261 210 205
Cable Length: 510 mm
Porsche: 911
122,40 EUR
Contains: 1 ite
Here is a different brand that claims to be the same thing:
http://www.rockauto.com/catalog/rafr...930583-7960379
154,80 EUR
Contains: 1 item
Porsche: 911
141,70 EUR
Contains: 1 item
Porsche: 911
122,40 EUR
Contains: 1 ite
I am going to shoot from the hip. The TDC sensor is for use only when "tuning". It is an external sensor for measuring rpm and tdc. IIRC it is not in use.
The 928 guys actually turned me on to it being a tuning port as most of them remove or ignore it.
Guess I will save a few bucks and not worry about this one.
I'm glad this was brought to a conclusion for future owners to read and comprehend.
"Guess where they terminated? At the three pin terminal under the IAC..... Yep, for tuning purposes."
No wonder these cars so are expensive ... all the spare parts that "do nothing" thrown in
Thanks for chasing this one down.
Glenn
Glenn
Luckily I didn't replace it. I was doing an inventory of things that needed to be done and found the TDC sender on the engine and thought "This will be a royal PITA to change with the engine in the car". So I hunted for the part to see the cost and found it NLA.
Then I did a little more digging and found it serves almost no purpose for practical uses so..... The old one is going back in.
