Will I cause any harm by driving w/o speedometer or oil temp gauge?
It has always been recommended that if you change the temp guage to the numbered one that you should put in a matched sensor. They could be many degrees apart.
Well, the gauges are out of the car. I'll be sending them to NHS right after I pack 'em up.
I may not end up doing too much driving while they are out, but I'll definitely watch my speed and I won't push the car hard so I should not have any temp issues. (I'll keep an eye on the oil level.)
If I have NHS do the temp conversion, he also sends the correct sending unit back with the gauge. (Thanks for those links, John, maybe I'll just get the new gauge fronts from Vintage.)
Sure, but it would be dumb. How would you know you were overheating or your oil pressure was failing, until the motor gets to catastrophic failure?
I had a 76 912E that wouldn't start if the tachometer was removed. I'm not sure what yours will do, but those instruments were put there for specific reasons. Good luck.
Team Owner
What Ron said is actually true in some of the early cars .. the tach would provide the pulse to the engine management and kill it should overrev occur .. i imagine that removing the tach could remove that signal causing a no start.
However that aside you can definitly run without guages .. But as Ed refers to.. do you want to do that ? .. I am sure that guy was steering the titanic blidfolded.. the ship would go fine as it doesnt really need it to go ... until ...
