fuel vapor lines replacement
8th Gear
The yellowing, hard plastic fuel vapor lines need to be replaced. They are all pretty much cracked.
The dealer states that they are NLA. Any leads on replacement hoses?
Thanks, Ray
Thanks, Ray
Since they are NLA from the dealer, I suggest you go to Home Depot and look at their clear hoses. They don't have to be hard...probably better if they aren't. Make sure you get the size that fits the best and use a small clamp, if necessary, to ensure there are no leaks/fumes. Just because it came on the car doesn't mean it has to go back that way. That's what I did to fix mine and the flexible new lines allowed for better positioning in the trunk. My $.02.
