H4 headlight wattage questions
#31
Those damn OEM headlight seals are worthless - I replaced mine 2 years ago and the new ones have already come apart at the seam. Ugh. Rusnak's suggestion to align the tabs is a good one - you can do it with a needlenose if the icepick is too scary :> I've got those nylon sockets and they're just fine, no heat issues at all. You are going to pee your pants the first time you switch these on in the dark.
#32
RL Technical Advisor
and Steve, Thank You![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Now,..you'll be able to see at night.
#34
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
This picture is on loan from imcarthur for use when splicing the wires.
Have you seen the boatload of links he has compiled? It should be a sticky.
#35
http://www.pelicanparts.com/cgi-bin/...o%20H4,%20each
Shouldn't I just go with two of them and call it a day?
#36
I haddah Google dat
Without knowing what you have, and what is required, I would say no, don't order the adapter. The reason is that the normal H4 socket is bad (loose) enough, and those things take a lot of vibration and road shock. Having two piggybacked onto the back of the headlight, all cantilevered out like that can't be ideal. And then there is all that amperage to screw with your connectors.
If you are stuck, post some pics and describe what you're contending with, and us non-H5 guys should be able to figure it out.
#37
#38
Here are the old and new sockets from front and back. Once I took the boot off the H4 and took a good look at the wires it will be a simple matter of matching up the colors. I remember that brown is ground but I gotta pull the Bentely to confirm the others.
Last edited by Amber Gramps; 01-11-2011 at 11:10 AM. Reason: Pictures were way too big
#39
I haddah Google dat
You could just hook the voltmeter up, and see which is low and which is high.
Halogen lights like tight connections and low resistence, so make sure you use a good crimp tool.
#40
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#42
basically I just gotta confirm that yellow is low beam and blue is high beam (I know brown is ground) and that the slots in both the H4 and H5 are oriented in the same general location.
Black will splice to brown (ground)
Green will splice to yellow (low)
red will splice to blue (high)
#43
I haddah Google dat
Seems straighforward. I think OSH has some high quality heavy duty crimps. Otherwise you might have to go with McMaster. Kragen or Autozone crimp connectors are not so good.
btw - I'm trying to lose weight, so I have been excercising more with free weights at home. Steady progress takes time. Don't hurt yourself!
#44
and I finally broke out the Bently manual and the wire color/beam combos are as listed above.
Now to figure out the relay...
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
#45
Must mix that aerobic with anaerobic,..that is, if you're looking to "burn" those calories.
Equally important: caloric intake (and what kinds)....
Interested in this thread, as I'm an H5 guy lookin' for good lumins (NOT headlamp lense changeouts).
MANY THANKS!
Doyle
MANY THANKS!
Doyle
