New guy needs help on G50 Tranny fluid change - hole in tranny?
Also, once you get the right tools, make sure you loosen the top (fill) plug first and then the lower (drain) plug.
If you empty the case first and then can't get the fill plug open for some reason, you have to tow the car to a shop, etc. because you can't drive the car with "dry" tranny.
Hey Jeff (jwillson95),
Would you mind posting pics of your rear bumper, including some low to the ground angles, please? I'd like to see how the GT3 muffler looks with center exhaust on our cars.
A guy over on Pelican recently posted a through-the-bumper exhaust, 2 pipes out between Euro bumperettes, the liscence plate in between the exhaust tips. Looks really neat, but it is a tight fit, and therefore heat might be an issue. http://forums.pelicanparts.com/porsc...gh-bumper.html
OP, sorry to go a little OT on you, but surely some pics of very nice cab won't offend you??
Thanks everyone,
AlfonsoR
Thanks everyone,
AlfonsoR
