911/951 Shop in Northern VA!!!
Both my girls need some attention while I'm back home here from college. Does anyone know of some great shops / mechanics that they could recommend?
Thanks!
Thanks!
I've been extremely pleased with the work at 2 places up here:
AutoSportsystems Group (ASG), in Merrifield/Fairfax, <a href="http://www.autosportsystems.com" target="_blank">http://www.autosportsystems.com</a>
and
RPM in Newington (ask for Stan).
What are you having done?
Both shops are great and I recommend both highly, but if it is any indicator for you, ASG is the cleanest joint you'll ever see -- could probably eat off the floor. To me, that says they run a pretty tight ship.
and
The 911 needs some valve seal work most likely....smokes quite a bit on startup
The 951 needs all belts (including timing belt with rollers and water pump) done ...do you recommend that I order that package separately and bring the parts and the car to the mechanic, or is that not something that I should worry about?
Check out these threads:
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=1;t=002699#000003" target="_blank">Local Repair Shop</a>
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=1;t=001560#000005" target="_blank">Repair Shop</a>
