Leakdown Test Question?
A leakdown test will only give an indication of ring and cylinder wear, and degree of valve leakage. It will not tell you anything about worn guides or broken rings.
When each cylinder is pressurized with air, the percentage of air passing by the rings & valves is displayed on the instruments guage. Observing where the air is leaking from gives an indication of where the trouble (if any) might lie.
Note that:
Air leaking from the air cleaner opening is leaky intake valves.
Air leaking from the exhaust pipe is leaky exhaust valves.
Air leaking from the oil filler tube indicates worn rings and/or cylinders.
Leakdown testing done by experienced and competant personnel is a valuable and indispensible diagnostic tool.
