About to pull the trigger, help me clear my head
#31
Its easier to drain the oil, as if you just undo the covers you will have a real mess. If you jack the car up on one side and do that side first, and let the oil drain away from the cover, then yes you can do it without a big mess.
#32
#33
I just bought an 88 with slightly less miles than yours but a little bit more $$$. My coupe also had minimal service records so a PPI for me was a must. My PPI results came out fine and I the oil did not have to be drained to check the head studs.
For what its worth I just got back from a 500 mile trip driving the 88 through the GA/NC/TN mountains while visiting my family. I have not had this much FUN in a log time!
#34
#36
My own $.02........and this is just my opinion - get a good air cooled Porsche mechanic to look at it, and he will use a mechanics stethescope. I don't think you need to go that far unless you hear noise. After all, you are going to get a leakdown. If it checks out, then it's going to be time to sh@t or get off the pot. The guy lowered his price, and is agreeing to a ppi. That is a lot to ask on what looks to be a nice Targa, fully loaded, no less.
Any thoughts on this temp measuring method?
#37
If I wanted to know compression, I'd get a compression test. Having said that I ca understand the theory of measuring temp. That may work, but I've never seen anyone do it or claim it works. It seems like it could maybe diagnose a truly bad cylinder, but can it detect a cylinder that was 20psi off of the others?
#39
there is not a crystal ball involved in this is there....?
heat detector??
sounds like a lazy way to check things over - I think it might be possible to tell if a cylinder is lean this way..., maybe lacking lubrication - but compression ?
heat detector??
#40
It's your money.
#41
I don't know. You sure could tell if you had no ignition or fuel in a given cyl, that's as far as I'd ever expect to measure such a way. As Ed says, sounds like a lazy way to do anything.
Let us know how it works out.
#45
Your tech might use a decible meter, you know - to decibilate each individual cylinder, and test the audibility factoring index of each one at 30 degrees past dead central.
Sorry, bad joke. Ignore that. Lol.
