just fixed my tranny...
Hey guys...
Just got my tranny fixed (was stuck in 3rd and with a little help from Phd Porshe got it back out ) but before I get it back on the road I need to put back oil, and get it re-insured.
1. How much oil should I put back in the tranny ( I have an 83 SC Cab with a 915)? and any tricks?
2. Seeing I just use the car on weekends, and not that often do you guys know of any occasional driving car insurance companies?
Thanks a lot for your tips.
I have an '84 911 could not get the fill plug or drain plug to move. I had to take it to a mech. I was doing it correctly just not applying enough force...hard to believe since my left hand is still bruised from three days of pulling. The trick is not to use a 17 MM tool on a ratchet/or breaker bar (it is way too large to fit in the close area), but to use the 17 MM Allen wrench...then the mech. used a very large pipe (for leverage) and, pop it broke free. The allen wrench has just enough bend to fit in the tight area whereas the tool I was using (which I thought would be better)was too large and bulky. Hope that helps.
...Good Luck!...Great Weather Is Coming!...Try Therse Folks <a href="http://www.lelandwest.com/" target="_blank">http://www.lelandwest.com/</a> I Am Very Happy With Them, Must Have A Garage, Primary Car, Pics, And A PCA Membership...LATER, AL... <img border="0" alt="[bigbye]" title="" src="graemlins/xyxwave.gif" />
Oil pump might be handy, there cheap and at the local auto store. It's a pain getting the Swepco thru the side of the tranny with out a pump. I use Parrish/Heacock for my Insurance, for a 12,000 agreed value/0 deductable and a 3,000 mile limit it was $250.00 per year. Must have primary car, garage, over 30 years old and good driving record.
Rick
Rick
Use a long piece of clear hose from local home improvement center, about five feet, and feed one end into the transmission and put a funnel on the other end. Run the hose from under the car and set the funnel end on a ladder. (hint: funnel must be hire than the transmission... ). Pour fluid, swepco 201, in until level with fill hole/over flows. Works great and it only cost a couple of dollars for the hose.
