Brake Calipers
No you can't, without mods. I've done this to mine:
1. Adapters needed to bolt front calipers on.
2. Larger front rotors such as Willwood with hats are required.
3. One of the rear holes needs to be plugged and redrilled.
4. 930 rotors for rear.
5. 23mm master cylinder reqd.
6. The proper 16" wheels-stock won't work, or 17's will be required.
I'm sure there are tons of threads on both brake conversion and wheels here.
Someone such as Steve Weiner at Rennsport, a sponsor here, can probably fix you up.
