please help decode Ferodo brake pads
Bought some used brake pads, and the seller wasn't sure if he put the pads back in the correct boxes. He has 2 sets of Ferodo's - DS 11's (race pads) and AF 11's (street pads). There are markings on only 2 sets (1 set of front's, 1 set of rears). Does anybody recognize the following?
1. Textar TP 22 HH 13.8107-4096.2
(?) 4164 GA
This pad had a 'wear slot' down the center, and also has a green and yellow mark on the top of the pad. (all the other pads are solid).
2. FER 2411F FF 0715
I've been told there is a significant difference between the two pads, and would prefer not to experiment on the street as to which stops better.
Thank you in advance....
(?) 4164 GA
