911 Forum 1964-1989
My First Porsche
Old 06-03-2010 | 07:21 PM
ivangene's Avatar
ivangene
Parts Specialist
used tires, what was is the MFG date?
tire rubs = fender sanding? seriously?
seriously?
Old 06-03-2010 | 10:27 PM
Fantor's Avatar
Fantor
Anyone else with some input???
Fantor
Old 06-03-2010 | 11:03 PM
irobertson's Avatar
irobertson
Tires rubbing on fenders can't be good.
Could lead to a tire failure at the worst time, when you're hard in a corner.
It will wear off any paint or corrosion protection on the inner lip of the fender, which will lead to rust.
I wouldn't grind or sand the fenders. Again, corrosion.
Some guys have the inner lip "rolled" to provide more clearance.
Old 06-04-2010 | 03:24 AM
rusnak's Avatar
rusnak
I haddah Google dat
I think those tires are probably way too wide.
Old 06-04-2010 | 08:26 AM
theiceman's Avatar
theiceman
Team Owner
What exactly is your issue . ? you couldn't find tires any more that fit your original rim or you don't want to spend the money ? to put tires on that don't really fit cause you got a good deal and then are now considering modifying the car to fit your cheap tires is not the way to start this relationship with your car.
