Rear Valve Stem Suggestions
I need to replace the valve stems on my rear fuchs. (The have a slow leak and tightening doesn't help.) They currently have the alloy stems that are fastened down by a nut on the top. Should I go back with these or will the standard rubber ones be fine?
I have the standard rubber and they work fine. Kind of wish I had the alloy stems like yours as my rims are brushed alloy. If you do change to rubber, you will change all four, won't you?
Team Owner
I kept the original alloys on mine to . I had to upgrade them to more modern looking ones, kind of wish I had as my 20 year old ones are looking tired and a bit coroded.
