I just adjusted mine last weeknd coincidentally. With the car off the ground the wheel should be difficult to turn at 2 clicks . This translates to 3-4 clicks while on a slight incline to stop the car . at 5 you should be draging the car without the wheels moving .. mine took 5 to stop the car on a slight incline so i did the adjustment as there is no room left after that. now it stops on an incline after 3
