Intermitant Speedometer
Hello,
My 1987 911 Carrera was used only 10-12 times during the past 18 months due to an overseas assignment. Now that I began using the car weekly, the speedometer and odometer only begin to work after I have driven the car 3-6 miles. I believe that the speedometer on the 1987 911 is electronic (not cable driven).
Would somebody have an idea what the problem may be or where I should start to look at? Any guidance will be greatly appreciated.
Best regards,
Angelo
Best regards,
Angelo
My 87 Carrera did the same thing, worked after a few miles, then progressed to working every so often, to not at all. Could be in the sending unit or the speedo head. I had the speedo rebuilt first, odometer also failed, which did not resolve my problem. Results came when we replaced the sending unit located at the trans. Hope this helps.
Rmurph & Pmgoodwin,
Thank you for your feedback. I am going to look into both of these areas.
Pmgoodwin,
Question: where were you having the bad ground connection.
Thank you,
Angelo
Pmgoodwin,
Thank you,
Angelo
