Door touchups
Hi guys,
Now that my garage is finally done, I have the ability to do some work on the car.
This evening I decided to give the Dr. Colorchip repair kit a try on my chipped door. This is the first application of the touch up paint, so we still have a ways to go to completely fill in the chips.
I am thoroughly impressed by how well this system works. The blending solution is truly amazing.
irobertson, I was wondering about their ability to match 23 year old "venetian blue". Based on your experience so far are you happy with their ability to match the paint?
I am leaning towards getting their kit as well. Any advice of which kit to get now that you've tried them?
(Your pics are helpful, but it's a little hard to tell for sure, plus, I know you're not done yet.)
Thanks, Venetian Blue Paul
I got the standard kit for the 911, and the basic kit for my Jeep at the same time.
I found the colour match to be spot on and it does well to hide small chips.
It does not do so well on the larger ones (like 1/4' or bigger) due to it being impossible to get the paint applied smoothly.
I found the metallic particles do not spread evenly in the larger wounds like they would if you were spraying.
The little chips come out great tho.
The process is:
1) Fill the chip
2) Smudge the excess across the existing paint
3) Let dry
4) Blend the excess away with the solution.
This leaves a nice clean area with the chip filled in part way.
There were some on my hood that, once done, I literally couldn't find them again.
I tried going at some of them a second time by filling the chip the rest of the way, but I could never seem to get any more buildup of paint in the chip itself. I'm going to try another technique for smudging it, as I think I'm pulling too much paint out of the chip the way I'm doing it now.
Off to Toronto this weekend, so it will have to wait until next wekend before I get back to it.
cheers
The process is:
1) Fill the chip
3) Let dry
cheers
Thanks for the additional comments on the kit. I think I'll give them a try on a couple door chips and one bad one near the trunk badge. If nothing else, a good color match will at least make the chips less obvious.
