rough idle - vid
Parts Specialist
OK - so thanks guys, I will start looking tomorrow night. tonight I am having fun with motor mounts (club sport) and tranny (same) then the wevo coupler.... fun stuff first -
I swear I have the bentley manual in pdf on my desktop. anyone have a sample page i can compare to?
TIA
TIA
Parts Specialist
OK - well I feel a little more comfortable under the hood... I will try the CO2 check - I did check the idle air control valve. Manual sayd I should hear it "hum" and I cannot.. I checked per the manual battery voltage at center with key on (is slightly less than battery voltage about 12.5) and the resistance from terminals on the unit 40 ohm and 20 ohm checks fine...still I thought it should hum? AND the motor runs the same with it unplugged which i thought was wierd.
so I will keep looking and it good to get a little learning in -
BTW I popped in my wevo coupler
Easy squeezy - good kind of job
