power mirror problems
I'm not getting any movement from my '87 mirrors. If I move the joystick controller, I don't even hear any motor sounds. Just got the car a few months back, and fortunately the mirrors were already in the perfect spots, but I don't know if they were working and have stopped, or were not working to begin with. The fuse seems good, no obvious pinched/worn wires through the doors, any thoughts?
I had the same problem with mine when I first got the car. I took the door apart and found the wires weren't even connected! A body shop had stopped short of full reassembly. One wire had also been clipped behind the dash for some reason. Get a cold one, a multimeter, a Phillips screwdriver and go to work On second thought, if neither is working, check the selector switch under the edge of the dash - maybe the common wire has come loose.
