tune-up
'84 911 should to do a tune-up myself or is this over the top and should be done by a Mech?
I have just recently pulled out the Cat and straight piped it, now I have back firing on upshift and downshift....I understand I need to adjust the fuel. I am assuming I do this during the tune-up. How hard?
The annual tune-up on a 3.2 Carrera is very doable for the average home mechanic. Wayne Dempsey's book (101 Projects for your Porsche) has details on most of the tune-up tasks and Bruce Anderson's "911 Handbook" has a list of all the annual tune-up tasks for a 911.
I can easily do the annual tune-up on my '84 Carrera in a day (at a leasurily pace). The valve adjustment takes the most time (YMMV).
The popping you are experiencing is most likely due to your mixture getting to lean as a result of straight piping your car. You should use a CO meter and reset your idle mixture to richen it up a bit. I set my idle mixture to about 3.5% CO using a Gunson CO Meter and I have no popping from the exhaust.
Bruce
Bruce
