911 Forum 1964-1989
Ruby's Rebuild Redux
Old 02-22-2010, 07:42 PM
Amber Gramps
Amber Gramps's Avatar
How the heck did you miss that last year?????
Re: "Amber Lamps"
Thread:
https://rennlist.com/forums/off-topi...s-whoopin.html
Post:
https://rennlist.com/forums/7328864-post190.html
Really good reason to pay for membership...
Old 02-22-2010, 07:48 PM
Ed Hughes
Ed Hughes's Avatar
Originally Posted by whalebird
Hey, did you decide against the Extrudehone?
Yes, too marginal a gain to justify the expense.
Old 02-22-2010, 07:57 PM
Amber Gramps
I had to go to google to figure out what "extrude hone" was:
http://forums.pelicanparts.com/porsc...intake-tb.html
Old 02-22-2010, 08:20 PM
dshepp806
dshepp806's Avatar
Don't go to the OT too much at all......I will occasionally step in and jab but retreat quickly (once I'm done)...
.......caught the RUSH T-Shirt thingie....
This upcoming thread from Ed will be a good reason to pay for membership!
As to RUSH relationals (to the video URLs), clearly this piece from "Kid Gloves" (RUSH) is resonating:
Anger got bare knuckles
Anger play the fool
Anger wear a crown of thorns
Reverse the golden rule
Then you learn the lesson
That it's tough to be so cool
Handle with kid gloves
Then you learn the weapons
And the ways of hard-knock school
Put on your kid gloves
Back to Ed's thread............................................
Best,
Doyle
Re: "Amber Lamps"
Thread:
Post:
Old 02-22-2010, 09:00 PM
Peter Zimmermann
Peter Zimmermann's Avatar
Well, I found my tech article file, and the one I'm thinking about isn't there. I will continue looking, but I don't have much hope that it survived all of the moves, changes, etc. Rats!
Old 02-22-2010, 09:24 PM
Ed Hughes
Ed Hughes's Avatar
Pete-No worries. The fact that you remember this being an issue you've seen is comforting to me. I was scratching my head yesterday trying to figure out how this could happen.
Old 02-22-2010, 11:07 PM
rusnak
I haddah Google dat
rusnak's Avatar
Maybe the body twists upward? In other words, the floor could be bowing in the middle, and accel/decel or braking might be causing flex.
I noticed that the Cabs have a different motor mount than the coupe or the Targas. I think they were planning for body torsion, or twist from side to side, but I doubt that would cause those tears. I wonder if you could rig up someting to measure front to rear flex?
What to the motor mounts look like? Are they oblong? In which direction?
Old 02-22-2010, 11:20 PM
Ed Hughes
Ed Hughes's Avatar
I don't think that you can tear this with flex. I've actually done a lot more track time prior to my build than I have in the last couple of years, so if it was going to happen from flexing, I would've expected it then. In fact, with my chassis much stiffer now, I'd think there would be less flex. Motor mounts are fine. If there was a heat treatment issue or whatever as Pete remembers, maybe mine just took longer to show up.
Old 02-22-2010, 11:38 PM
whalebird
whalebird's Avatar
Rusnak, that's pretty much the argument against a targa or cab - there is a flat floorboard between the front and rear, held only by the door latches. I've never seen one, but I've always thought it would help to make a brace to replace the targe "top". A trussed unit that would attach using the same hardware(pins and latches) as the original top - just welded to tube structure that could be removed just like a targa roof.
Anyway, I don't think it makes a huge differance as long as Ed caught it in time.
Shepp, "Kid Gloves" and P/G will have to go PM. It gets pretty soupy in OT sorry to send you there.
Old 02-22-2010, 11:48 PM
rusnak
I haddah Google dat
rusnak's Avatar
I wonder if there would be micro tears or ripples in a coupe at the B-pillar? That would be a point of stress. I could see how the floor would be a huge pivot in an open car, unless the rollcage were triangulated front to back across the passenger area.
I don't know how that engine mount tore. It couldn't happen with just heat from the muffler. I have to go check mine this weekend.
Old 02-23-2010, 12:30 AM
whalebird
whalebird's Avatar
Good point rusnak. Thats why Porsche and any other carmaker spotwelds a unit-body - it allows a perscribed amount of flex. It's common to "seam weld" race cars where all the sheet metal in the tub is connected with a continuous weld. Spot welds allow the structure to flex a bit, otherwise the chassis structure will begin to split apart at the seams. This is fine for a dedicated race car(limited life span), but spells the end for a street car.
I think Ed's failure comes from being in the most extreme environment on the car. Peter's got this figured out.
Old 02-23-2010, 07:40 AM
f4 plt
f4 plt's Avatar
Originally Posted by Ed Hughes
I figured I'd start a new thread now that this is in progress.
Recap: I built the engine two years ago and spared no expense other than using my original pistons and cylinders which were within spec. I recently got a set of new Mahle 98mm 10.5:1 compression pistons and cylinders which are going in, along with twin plugging. I do not intend to split the case again.
So, the motor came out yesterday, and today I stripped the top of the engine down. I'll start on some exterior cleaning next weekend before stripping the topend down and removing the old "jugs".
Some pics from yesterday and today:
What is the lift? I have the Snap-on lift and built similar ramps out of 2x 4' I laminated together. less clutter than a four post Nice garage
Old 02-23-2010, 10:05 AM
Ed Hughes
Ed Hughes's Avatar
Bendpak
Old 02-23-2010, 10:39 AM
SeanR
SeanR's Avatar
Subscribed for following.
Well done Ed.
Old 02-23-2010, 11:32 AM
pmason
pmason's Avatar
Here is what I did to stiffen up my Targa. Now I didn't notice much flex before, but deffently can tell a difference when the rollbar was installed. Even before this the shop I take the car to commented that it was pretty stiff, in that it didn't sag when on the lift and the doors remained lined up.
This was last winters project, this year I'm putting on headers.
Quick Reply: Ruby's Rebuild Redux
