Who here lowered there car themselves?
#31
I haddah Google dat
M491, what did you use for a pivot? I've been thinking of using a large socket on the front cross-member in the front, but I'm way skittish about putting that kind of pressure on the crankcase all in one spot on the rear.
#32
Well, there have been untold numbers of 911's jacked up at the crank case without any issues....
Maybe a socket or similar with some kind of "hockey puck" on top to spread the weight a bit. Weld a fixture that sits on a jack or jackstand.
#33
I haddah Google dat
That's a brilliant idea, Ed. Something between the pivot and the engine case, so the lifting force is not concentrated on the crankcase. I wonder if I can use my lifting platform that I made for the engine drop but bolt a pipe nipple fitting to the underside. I could lift the whole thing with the trolley jack.
