Central locking gremlin
Hi Guys,
I have a 1989 3.2 cab. The car has a little problem with the central locking. The key and the door ***** all work perfectly. It is the lighted lock button operation that is flawed. The button will glow when the parking lights are on as it should. However, the button will only lock the doors if the parking lights are on. When the doors are locked, the lock switch remains glowing instead of going into the brightly lit mode. To unlock, the ignition needs to be on. I have used another lock button pad from another 911 and the symptoms persist, so I know it is not the lock button pad. I bought the car used from a dealer and was wondering if the ex-owner spliced or jump some terminals for some aftermarket alarm. I could not find any aftermarket stuff on it. My next step would be to swap out the control unit to see if this will fix the problem. Anyone else experienced the same?
Thanks,
Steve
Thanks,
Steve
I *think* the lock button only works with the key in the "on" or "run" position. I think it was designed for use while driving. If the key is out it may not work. That's how mine works and it appears to be unmolested.
I spent a few hours yesterday on this. Well at least I fixed the footwell blower noise while I was down there.
Steve
