911 Forum 1964-1989
Airbox question - '88
Old Oct 24, 2002 | 06:09 PM
Bill W.'s Avatar
Bill W.
Post Airbox question - '88
While replacing the rear shocks on my '88 I had to remove the air filter enclosure (airbox) to get at the right side shock. When I went to re-install the airbox I found there was a porthole (apx 12mm) that looked like it should have a vac. line going to it but there were no unattached vac lines in the area. What am I missing?
If it weren't for the fact the hole is on the intake side of the air filter I wouldn't worry about it but since this effectivly bypasses the air filter I'd like to know what should be attached there. If nothing is attached I could use a large vac plug to cover it. I can't start it to check to see if she runs rough until Sat.
There was no mention of this in the Bentley manual.
Thanks,
Bill W.
Old Oct 24, 2002 | 06:25 PM
tchanson's Avatar
tchanson
Post
Bill,
Are you referring to the attachment for the oil vent/breather tube that should run from the oil filler tube/neck to the air box on a 3.2? That would be my guess.
Tim
