Porsche Battery Tender
Anyone out there using this Battery Tender? 980-611-981-00-OEM
Attachment 401285
It is that time of the year and I'm not sure how much I'll be able to drive the car this winter...so I'm preparing just in case the car sits for a while.
Attachment 401285
I haddah Google dat
I'm not familiar with that one. I got a cheapo float charger and battery condtioner gizmo somethingrather from HF that works great. Just make sure that it shuts off when the battery is fully charged.
Team Owner
just plug it in the lighter and plug it in the wall . You have to have a "hot" lighter with ignition off , and it only supplies a trickle charge to top up the batery if it senses the voltage has dropped off. The newer Porsche ones are made by C-tek. I have a C-Tek and it works fine. I have the 3300 I think it is called .. does not have lighter option but I can't use it anyway. The quick disconnects are great when you forget about it .. I have dragged a battery tender more than once down the driveway
Works great...
Great! I will add it to my Porsche X-mas wish list...it's a long list but this item is probably the cheapest one.
