3.0 40 weber cam suggestions
RL Technical Advisor
Your main limitations are imposed by the stock CIS pistons so I'd use a 964 cam.
If the car doesn't need to pass smog tests, you need to install SSI's and a GOOD sport dual-inlet muffler otherwise the above cams are a big waste of money.
If you don't need heat or defrost, you can use a properly made set of headers and street adapter pipes, too (along with the same muffler as above.
I can help you with the exhaust system, if you wish.
Last edited by Steve Weiner-Rennsport Systems; 11-18-2009 at 07:09 PM. Reason: Edited for accuracy & context
