Door Panel Removal on 85 carrera
Hello,
I am stuck in this exercise and I need some advise.
I am using the "door panel removal" article from the Pelican Part web site.
<a href="http://www.pelicanparts.com/techarticles/bob_tindel/911_door_panel_remove.htm" target="_blank">http://www.pelicanparts.com/techarticles/bob_tindel/911_door_panel_remove.htm</a>
The step 2 tells:
2. Remove the rotary unlocking ****. Pry the cover off the center of the **** and remove the Phillips screw.
I am exactly stuck here because once the **** is removed there is a larger circular plastic part tha needs to be removed. For that I have to remove a kind of 3/4 metalic ring that tied this up to the door panel. Do I need a special tool for such a small part or is there a trick to get rid of it?
Thanks,
Yann
The step 2 tells:
Thanks,
Yann
It unscrews. <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Easy - huh?
Just turn the whole thing and it will come right out <img src="graemlins/jumper.gif" border="0" alt="[jumper]" /> <img src="graemlins/jumper.gif" border="0" alt="[jumper]" />
Easy - huh?
