911 Forum 1964-1989
Slow Window
Old Feb 11, 2002 | 04:54 PM
Vampire's Avatar
Vampire
Question Slow Window
The passenger window in my ’86 coupe is moving up and down very slowly. The car is new to me as of November and I have not driven it much due to the winter. This last weekend, I was working on it and noticed the problem was worse than before. I don’t know if the cooler weather made it worse, or if it was just having a bad day.
Does anyone know the cause or solution to this problem?
Thanks in advance.
Old Feb 12, 2002 | 06:27 AM
carlitox33's Avatar
carlitox33
Cool
My ´86 carrera does the same thing, but with the driver´s window. It´ll go a lot better after washing the car, or in warm weather, it gets REALLY slow when it´s cold outside.
Grease could be a solution, however, greasing the window rails is not good, as it picks up grime and will end up blocking the window.
Graphite grease (dustlike) works really well, and it will not pick up any grease (works excellent for aerials)
Old Feb 12, 2002 | 10:59 AM
Cary E's Avatar
Cary E
Post
Couple of things..........
1. Find every connection and clean it with a copper bristle brush. Make a NEW connection.
2. Window channel felt wearing out and binds on the window.
3. Replace the window switches. They wear out.
Don't jump into replacing the motor until you've done everything else. BTDT
Old Feb 12, 2002 | 01:50 PM
Want to be's Avatar
Want to be
Post
Red 911,
Graphite powder is the ticket!
I had the same problem with my 88 coupe , my mechanic used the graphite powder in the window channel and all is GOOD.
jpc
<img src="graemlins/jumper.gif" border="0" alt="[jumper]" />
