Door locks then unlocks.
The oor lock on our '88 Carrera are acting up. Both locks will lock, key or central, but immediately unlock...? I've been having to manually lock the driver door reaching across fron the passenger door/side and then lock the passnger door manually.
I had that problem and found the rod inside the door that adjusts the length of the rod from the door lock to the switch was off a little. I just tried it a turn or two each way until it worked properly.
