Unusual Headlight problem??
Yes, I have done all searches. It is not the switch or steeringcolumn switch.
I have checked both the lightswitch and the steeringcolumn switch and I have full power on both low/hi beam at the fuses. On my car it looks like I have an original relay connection because at the low and hi beam fuses I have one thin cable out from one of the low beam fuses and one from the hi beam fuses. Hence 2 fuses are not used. What is my problem then?
I cannot find the relays (or other fuses). Then the thin cables are going into the original cablelooms, not easy to trace them.
Very thankful for some help. I have not checked the power or ground at the bulbs yet.
Team Owner
okay so what is the problem statement ? that might help
also what car is having the problem?
PS there are no relays for the headlights, some people like myself have added them..
Thanks Iceman
87 Carrera it is. No hi or low beam, just parkinglights. For sure I must have relays some where, due to the connections at the fuses. Just cannot find the relays. No problems with switches. I am a bit puzzeled due to the good looking cablelooms. I understand it sounds weird, but it looks very much as a factory solution judging the way the cablework is done. I have to measure at the H4 sockets as next step, but I am pretty sure it is not the bulbs.
I haddah Google dat
Edit: Oops, sorry check Post #7 in this thread. Use a circuit checker. If you have power, then it's either the switch or the wiring.
https://rennlist.com/forums/911-foru...ng-lights.html
