911 Forum 1964-1989
Some Q's
Old Jun 8, 2003 | 04:31 PM
Amo's Avatar
Amo
5th Gear
Post Some Q's
Hi,
I have recently purchased a 1977 911, UK spec. It has a 1988 3.2 engine and super sport body.
I have identified some faults and would like assistance please.
1. When driving in heavy traffic, if I let go of the clutch with very little acceleration, the car starts to jerk and splutter. Is it that air/fuel is not getting through? Apart from that it drives fine, normal movement with normal use of the acceleration causes no problems.
2. The oil level gauge reads full all the time. Is it a sender problem? Is so where is the sender located? can I easily replace it myself? if so how?
3. The oil pressure gauge reads between, 3-4 all of the time and sometimes during driving it will become erratic and move violently. Is it a sender problem? Is so where is the sender located? can I easily replace it myself?, if so how?
4. The small side indicator light on the wing on the driver side doesn’t work. How can I take of the lens to replace the bulb?
5. When I press the wiper switch to activate the screen washers, I can hear the motor noise, but don’t get any water out. I’ve filled the tank to maximum. Any ideas?
Many thanks in advance for any help.
Amo
