Trick to cleaning front hubs?
Anyone have a trick for removing the accumulated brake dust on the front hubs? Mine are off for a wheel bearing change. After many years, and much heat, the grime on the hubs is TOUGH. Even the most aggressive wheel cleaner (the ones with acid) barely makes a difference. A light wire brush works, but you can't get into the nooks and crannies, of which there are many. I don't like bead blasting, either for how it looks or for how it can leave behind paricles to ruin the machinery. I want mine to look like the ones on that Carrera 2 in the latest Excellence!
Bead Blasting worked well for me. Just be careful, don’t use to much air pressure & keep the tip moving. Leave your old bearings in place & cover the holes w/tape. When done I sprayed mine w/silver (Worth) wheel paint. Still looks good after a year of street & track use.
