what's worse than no 911?
....being afraid to drive your newly purchased 1988 911.
Twice in two weeks as I was driving...once after 30 minutes...once after 4 minutes......the eninge just shut down.....like it was out of gas....pulled over to side.....wouldn't start....waited 5 minutes.....it started....
after searching Rennlist...I have clue it might be a DME relay.....one was last replaced...3-07.....
any ideas out there...just got my car July 2 after waiting 45 years....help...Dwight Johnson
I haddah Google dat
+1. DME relay is easy to check. Clean your grounds, and on the 3.2 911, the postive battery clamp goes bad and eventually needs to be replaced. We did a Rennlist no start checklist previously. You might want to look for it. On Pelican, there are a few knowledgable guys on the 3.2. I'd google Ischmitz because he's good and very helpful. The 3.2 911 is very bulletproof, and one of the most reliable cars you will own.
The carreras are pretty simple compared to modern cars - the DME relay is a known trouble issue - keep a spare - the other two main items that have issues are the cylinder head temp sensor and the flywheel reference sensors - they tell the DME brain what to do next. They reside in not the greatest environments - so it's common for their coverings to get cooked.
From there - Idle control valve - tends to stick. last but not least is the Bosch Barn Door air flow meter. It can get gummed up - the sensor can actually wear a path in the sensor media and cause problems.
This problem did not occur during your PPI???
thanks
thanks for all the comments...very, very helpful...problem did not appear in PPI nor during the 8 hour ride home....had it inspected by a respected Porsche mechanic in Warren , Mi..........nothing then either......again thanks...Dwight
Team Owner
damn now I did it ..
many possibilities,...settle down and work with these posters...don't freak out.
I've found the "experience of the walkthrough" with the fellow posters is one rewarding process..
deep breathe,...get started.
Best,
Doyle
Best,
Doyle
the envelope please
The prize goes to g-50cab. Looks like it might be the flywheel sensors. But now I need the Bosch #'s to cross reference and find the same part for the 1990 M3 BMW....same part but half the price. Anyone help here? Dwight
