I would like to lower my suspension..
#64
I haddah Google dat
Wheel shimmy is bad. In these cars it will put more wear and tear on your steering rack, bearings, etc.
You should definitely have the wheels balanced. The place that sold you the tires may do a free re-balance. It is not uncommon for me to go back at least once after buying new tires to have them re-balanced a second time during the lifetime of the tires.
#66
Team Owner
and even tires that ave been mounted and balanced and are NOT dierectional , once running one way can have issues when they are put on a car and run the other way. I think this will be your problem . Your right rear that is now your left front and vice versa are now running in oposite directions.
I would suggest talking to a tire expert and explaining your issue ... he may remove and remount.
