I would like to lower my suspension..
#47
holy ****!! Mystery solved! I just realized that the 7" are mounted on driver side and 6" are on passenger. I realized this after ricster made comment about the stems. I cant believe I never realized it. I feel stupid! To my defense its easy to fool the eye because they are on different side of car and can't look at them at the same time.
#48
I haddah Google dat
hooo boy. Never seen that before! Interesting dilemma now regarding wheel choice. A used 6" would be dirt cheap, but two 8" or 9" would not.
#49
Team Owner
i juat wana see the look on the tire rack guys face when you order one set of tires for the drives side and a different size for the pasenger side ..
#53
wow a ppi and they missed that??? What else did they miss? Thats a pretty easy one to spot to be honest. No it would not be an even swap..I think they will give you $600.00 for trade value and the 8's cost around 1600.00 for 2...so a $1000.00 my guess your in
#54
I just had all my Bilstein replaced and lowered to euro spec. My wrench just called and asked me to stop by and see if i wanted it even lower before he sets the alignment.
I asked him what it's currently set at, his reply was "9 in the front, 10 in the back"
Is that too high?!
Is that too high?!
#55
I haddah Google dat
I usually measure from the ground to the bottom of the A-arm in the front, and from the ground to the bottom of the torsion tube in the rear. It's too difficult to get consistent measurements using the fender to ground.
#57
I haddah Google dat
If it hits the rubber snubbers, and your car bobs up and down like a ricer on Fast N' Furious, then it's too low or needs the front spindles raised.
#59
ok, I put the rims on the correct side of car. Were they supposed to be balanced prior to mounting, because now im getting a shimmy from steering wheel at around 60mph?
