Suspension set up is EU spec ideal for all around use?
From what i understand, the US and EU specs for an 88 911 are quite different. What is the EU spec and is this a good set up for all around use? Daily driver with the occasional AC or DE. If not what set up has worked well for the folks on this list?
thanks
alf
thanks
alf
One thing's for sure, you're lower than euro. Your year, the car originally was "Euro" height. (They all were) Now you're sitting low.
If you have clearence problems, maybe take it 3/4" max up at all four corners. You'll spend money doing that, and then you need a corner balance and alignment.
rjp
rjp
