Rear caliper options for 79' SC with 930 rotors?
I have a 79 SC that has been a project car for many years. A couple of years ago, I was fortunate to get Bilstein coilovers and brakes off a wrecked 930 very cheap. This particular car had the original 930 rotors with 993 front calipers all the way around and used an adjustable proporting valve to adjust the brake bias. I got the conplete front suspension, rear coilovers, rotors, calipers, mounts, 930 master cylinder and the adjustable proportioning valve.
The fronts are a direct bolt-on, so nothing to do there. I am keeping the SC trailing arms, so the rear is really the question. I am not stuck on using the 933 front calipers in the rear. In fact, I am really thinking about using a pair of 993 rears or 965 rears as the brake bias should be acceptable without an adjustable proportioning valve.
Anyone have advice on these setups? What adpaters woudl you need and who makes them?
I used that set up for a few years it does work well w/o a p/v, you will want 17" wheels and 23.8mm m/c.
to fit either of those calipers, fill the existing axial mount holes w/ an aluminum plug, redrill to fit the 3" mounts and 309m rotors. I used to have pics on one of my sites but the site was taken down and I haven't gotten around to putting it back up. The 993 rears require additional work w/ a grinder to widen the throat area.
Alternately and much more expensive is to mill the existing mouting ears off and convert the calipers to radial mount(like the fronts). VCI offers this later method.
Thanks. I just bought a pair of 965 rear calipers and found a shop who will do the rest. Yes, I am going with 17" wheels. The car was converted to a wide body with 9" turbo front fenders and 13" rear quarters. I have a 930 M/C to handle the pressure.
