911 Forum 1964-1989
Dropped rpms mid- drive
Old 07-09-2009, 11:26 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,025 Likes on 729 Posts
no advice from RL ..... 1 year !!!
Old 07-09-2009, 11:29 AM
butzip
butzip's Avatar
Ed - that was a funny comment no offense RL
In RL's defense the OP's description was a little confusing.
Having experienced this very situation, I knew what he was saying. It's like discussions with my wife, largely incoherent to the casual observer but we understand what each other is saying
Old 07-09-2009, 11:34 AM
RL911
RL911's Avatar
Old 08-16-2009, 12:28 PM
I10C21M45
I10C21M45's Avatar
Doh! I'm in the middle of this problem. The Bosch 0227300004 CDI unit provides the trigger for the tachometer, so a "0" reading is very possible. I just went through the mini-diagnostic procedure and found +12 on pin 15 (red wire) of the CDI connector with the ignition switched on. The distributor sender is putting about 1.3 VAC into the connector positions 31d and 7. I then put the digital meter (AC voltage - 500VAC scale) on to the coil terminals and.....zippo! So it's either find another CDI box, switch over to an MSD unit and coil (and if it is like my '71 911 - tachometer hassle) or tear into this one and find the component that had the "smoke" escape from it. The MSD worked without a hitch (other than the tach) on the '77.
Quick Reply: Dropped rpms mid- drive
